Results 11 to 20 of 24
Thread: Bora fuel tank only filling to halfway
    Aug 2009
    brisbane qld
    i fill my golf at the same servo and same pump everytime. thats cus i know how that pump likes to fill but if i use any other pump at that servo it keeps cutting in and out so have to bring the nozzle out of the filler a bit more or have to use half trigger
    Jun 2008
    Cronulla, NSW
    this happens across multiple bowsers
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Mar 2009
    Wagga Wagga
    A bit offtopic: How much fuel is left when the warning light comes on?
    May 2010
    Perth
    im not sure how the 4mo distributes fuel going in, but it runs a "saddle" type tank whereby there are essentially 2 tanks linked together to clear the 4WD gear.
    Possible that there is a blockage or whatever with fuel not getting to the 2nd side of the tank?
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
    Jun 2008
    Cronulla, NSW
    thats a damn good answer Lone, thank you. How can we tell the internal design of the tank?
    Apr 2008
    My fuel tank senders failed on me, leaving me with a bone dry tank on the M5 when the guage showed 1/3rd of a tank left...
    Nothing to see here...
    Jun 2008
    Cronulla, NSW
    yeah, but this ain't happening to me. I've proven that the gauges work intermittently, but that fuel tank contents isn't in doubt as i measure based on kms. I think the tank isn't filling properly, but how to test? how to fix?
    Apr 2008
    Intermittent faults with them is how they start apparently. They eventually get blocked by stuff that builds up over the years - apparently you can get to them relatively simply by lifting the rear seats, it may be worth checking them out...
    Jun 2008
    Cronulla, NSW
    but what i am saying is that I think I have proven that the senders aren't the main issue, they are simply a potential secondary issue that i am not too concerned about (because i don't trust the gauges anyway). I do trust the fuel economy and therefore fuel consumption of the car, and so i go off kms per tank to gauge how full/empty the tank is.
    The proof is when I have travelled 650kms on a single tank (therefore close to empty) and when i am filling at the bowser i only get 35L in roughly before it starts shutting off. I then spend a good 5-10mins bouncing the car and doing the clickety-click with the bowser trickling fuel in until i get to 40L and give up. There is definitely an issue with the tank and/or baffles or something preventing me from filling.
    Can the tank itself be lifted from inside the cabin via the back seats somehow? Surely it couldn't be that simple.
    Apr 2008
    Oh yes, I realise not the main issue (senders won't affect how the tank fills from a bowser) - but they'll cause you other kinds of grief (like running bone dry at 90km/h on the M4 like I did! ) if they continue to claim there's more/less fuel in your tank than you think you have.
    Pulling the senders out means opening two ~20cm holes in the top of your fuel tank (due to the "saddle" design, there's one in each side of the tank). That may provide you with an opportunity to have a bit of look around inside the tank to see if there's anything obviously going on (may be able to see the state of the baffles, etc).
    Obviously this is something you want to do with the tank as empty as possible, out in the open or a well ventilated area, on a cold day, and not whilst smoking a cigar.
    Let me check my service manual to see if it gives info on removing the tank...
