Results 1 to 10 of 18
Thread: Bora Engine Series, How to tell the difference.
    Jan 2011
    Newport, Victoria
    Hi all.
    I have recently bought a Bora in need of an engine change.
    I am told there is two series of engines in Boras built around 2001.
    Does any one here know the difference, and how to tell if an engine is the early or late series?
    Are they interchangeable?
    It is also an auto, and I am told they are different from the eingines used in manual cars. Does any one know the difference here, other than flex plates / fly wheels.
    Apr 2008
    4-cylinder or V5 (can't be V6 as they were manual-only)?
    Nothing to see here...
    Jan 2007
    South Australia
    Engine code is under the floor in the boot next to the spare tyre on the sticker or in the car manual service section.
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Oct 2010
    Yarra Valley, VIC
    From memory there was a 125kw and 140kw or something similar in the V5 depending on year (not sure about the exact kw).
    Jan 2011
    Newport, Victoria
    Quote Originally Posted by Manaz View Post
    It is a V5.
    Jan 2011
    Newport, Victoria
    Quote Originally Posted by phaeton View Post
    I will take a look in the morning. There is no battery in it at the moment, so I cant get in there. (It is the hi tech security system).
    Is there a way to translate the code, and what is the physical diff?
    Be much easier if you need another engine to get the same engine code. Google the 3 letter code and there'll be something on wikipedia.
    V5 engine - Wikipedia, the free encyclopedia
    Mar 2010
    Lesmurdie
    Quote Originally Posted by chandler_ross View Post
    You should be able to get in the boot, Just stick the key in the lock and turn it and it should open i think? Or fold down the rear seats. Both probably not true haha.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Apr 2008
    Quote Originally Posted by sirmoe View Post
    110kw and 125kw
    Apr 2008
    The 110kW engine was single cam, 10v (2 per cylinder). The 125kw version has twin cams and 20v (4 per cylinder).
    I suspect the 110kW version also does not have individual coil packs in the head, but rather coilpacks on the side of the block like the Mk3 VR6.
    Regarding interchangability, you could potentially put the newer engine in an older car, but not vice versa. Lots of work required I suspect due to different electronics, would also require engineering. You'd be better selling an earlier car and buying a later one with the updated engine.
