Bora diagnostics
Hi,
Just bought a 99 V5 Bora.
It was running a little sluggish, so decided to do a service on it.
Put a K&N panel filter in, started the car back up and it started running really rough (limp home mode).
Got her hooked up to the diagnostics test and spat out these:
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 166720km/103595miles
Address 01: Engine Labels: Redir Fail!
Part No: 071 906 018 K
Component: MOTRONIC M3.8.3 HS V02
Coding: 10031
Shop #: WSC 01317
VCID: 1B3E54A3896B9FC0D47
5 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
00553 - Mass Air Flow Sensor (G70)
31-10 - Open or Short to Ground - Intermittent
00282 - Throttle Position Actuator (V60)
28-10 - Short to Plus - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
Readiness: 0000 1001
And more:
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 822 A
Component: KOMBI+WEGFAHRS. BOO V20
Coding: 07752
Shop #: WSC 00000
VCID: 234E6C43B11BA7001C7
Subsystem 1 - Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0X1184696
Ident.-Nr. WEGFAHRS.:VWZ6Z0X1184696
7 Faults Found:
00534 - Engine Oil Temperature Sensor (G![Cool](https://www.vwwatercooled.com.au/forums/images/smilies/icon_cool.gif)
30-00 - Open or Short to Plus
29-00 - Short to Ground
01128 - Immobilizer Pickup Coil (D2)
35-10 - - - Intermittent
01176 - Key
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
And finally:
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
VCID: F0E4D30FB06DCC98515
3 Faults Found:
So basically, would like to get the car running a 100%.
If I could, recommendations as to what should be a priority, and or possibly how I go about fixing it?
Thanks
Jovi
Clear the codes, drive it around for a day or so and then scan again. Those fault codes could have popped up at any time during the car's life so you just want to see what's relevant now.
It'll probably have something to do with 00553 - Mass Air Flow Sensor (G70). Check all the hoses and sensor, etc are all connected properly.
VW Bora V6 4motion
![](http://i1125.photobucket.com/albums/l594/janpaoloflores/bora.jpg)
Good advice. Clear the codes, give it a week, so what pops back up again.
Nothing to see here...
- You may not post replies
- You may not edit your posts
Forum Rules
