Results 1 to 5 of 5
Thread: Bora diagnostics
    Sep 2012
    Dandenong, VIC
    Bora diagnostics
    Hi,
    Just bought a 99 V5 Bora.
    It was running a little sluggish, so decided to do a service on it.
    Put a K&N panel filter in, started the car back up and it started running really rough (limp home mode).
    Got her hooked up to the diagnostics test and spat out these:
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
    76
    Mileage: 166720km/103595miles
    Address 01: Engine Labels: Redir Fail!
    Part No: 071 906 018 K
    Component: MOTRONIC M3.8.3 HS V02
    Coding: 10031
    Shop #: WSC 01317
    VCID: 1B3E54A3896B9FC0D47
    5 Faults Found:
    00668 - Supply Voltage Terminal 30
    07-10 - Signal too Low - Intermittent
    00553 - Mass Air Flow Sensor (G70)
    31-10 - Open or Short to Ground - Intermittent
    00282 - Throttle Position Actuator (V60)
    28-10 - Short to Plus - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - Intermittent
    01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
    Readiness: 0000 1001
    Sep 2012
    Dandenong, VIC
    And more:
    Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
    Part No: 1J0 920 822 A
    Component: KOMBI+WEGFAHRS. BOO V20
    Coding: 07752
    Shop #: WSC 00000
    VCID: 234E6C43B11BA7001C7
    Subsystem 1 - Part No: Ident
    Component: Nr. WEGFAHRS.:VWZ6Z0X1184696
    Ident.-Nr. WEGFAHRS.:VWZ6Z0X1184696
    7 Faults Found:
    00534 - Engine Oil Temperature Sensor (G
    30-00 - Open or Short to Plus
    29-00 - Short to Ground
    01128 - Immobilizer Pickup Coil (D2)
    35-10 - - - Intermittent
    01176 - Key
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    01316 - ABS Control Module
    01321 - Control Module for Airbags (J234)
    Sep 2012
    Dandenong, VIC
    And finally:
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 01317
    VCID: F0E4D30FB06DCC98515
    3 Faults Found:
    So basically, would like to get the car running a 100%.
    If I could, recommendations as to what should be a priority, and or possibly how I go about fixing it?
    Thanks
    Jovi
    Jun 2009
    Melbourne, VIC
    Clear the codes, drive it around for a day or so and then scan again. Those fault codes could have popped up at any time during the car's life so you just want to see what's relevant now.
    It'll probably have something to do with 00553 - Mass Air Flow Sensor (G70). Check all the hoses and sensor, etc are all connected properly.
    VW Bora V6 4motion
    Apr 2008
    Good advice. Clear the codes, give it a week, so what pops back up again.
    Nothing to see here...
