Bora crank but no start, no fuel or spark
Hi Gents,
So I was having a noise from the front of my bora, put it up and found a loose bolt, fixed that, went to go take it for a test drive and it just turns over and over, at first I thought it was the fuel pump as it wasn't running at all, so I changed it out without luck.
But further inspection showed that it is working after I stop trying to crank and when I open the door.
The codes I am getting are
P0113 - intake air temp (had this since I bought it)
P1639 - TPS
P1337 - cam pos sensor
P1391 - cam pos sensor
The cam sensor errors I have had for a little while due to the chains being stretched I believe. However I have swapped them and changed them with no change.
Any help diagnosing the issue would be great.
I do get revs on the tacho after a second of cranking, also after long cranking it says STOP on the dash and low oil pressure, it's almost like it thinks it's running...
- You may not post replies
- You may not edit your posts
Forum Rules
