Bora boot lock
We have just got a Bora and now its home I can not get the boot open.
The bloke we got it from says turn the key left but that does not work.
Here is what I have tried...as per the book.
Lock the car with the remote...unlock and try to open the boot....nope.
Put the key into door and unlock the car....try to open boot....nope.
Put key into boot lock, Turn anti clock(10mins to oclock) and the doors unlock and windows open.
Turn key clock wise(10 past oclock) and the windows shut and doors lock.
Turn key to quarter past and lock boot and take key out.
Each time I have squeezed the handle but the boot will not open.!!
Is there something we are missing?
Is there a way of opening the boot from inside if there is something broken?
Please help as the wife can not go shopping until this problem is fixed
If you know any info but dont know how to explain please send me a pm and I will ring you.
Thanks Rob
The boot has an electric release on the handle paddle thing.
More than likely the unit in the handle needs to be replaced, it is a more than common issue.
Put the key you have in the boot and turn anti-clockwise and the car will unlock feel resistance and then twist it that bit more. It will pop.
James your a star!!
It works...Thanks.
Will look into replacing the handle paddle thing asap.
Rob
- You may not post replies
- You may not edit your posts
Forum Rules
