Results 1 to 4 of 4
Thread: Bora 4motion timing chain advice
    Sep 2015
    Reservoir
    Hey guys wanted some advice on my 4motion bora as it sound like the chain is making some slight noises,
    Some options and tips would be helpful
    Mar 2010
    Lesmurdie
    I'd love to help but you really need to specify what your looking for? Are you doing it yourself? Do you want to know what it sounds like? What year is your car (it does matter slightly). Heres a decent guide on vortex (its for the 12v though) VWVortex.com - DIY - Replacing timing chains, tensioners and guides on a 12v VR6
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Feb 2014
    Batemans bay
    They are prone to making some noise !!
    Take your oil filler cap off whilst engine is running and you'll crap yourself !!!!
    Check for codes such as camshaft timing error which may suggest chain has stretched past specs or tensioner has reached limits
    Has the oil been changed ??
    If none of these are an issue then I'd suggest it's just normal for a car that's 10 - 15 years old !!!
    lots of money to fix ....
    Apr 2006
    VW Race HQ - Sydney
    The tensioner has a spring and runs off oil pressure .
    The oil pump has a spring and bucket which limits oil pressure
    The oil pump spring loses its ability to work against engine oil pressure and the car starts running higher oil pressure
    Higher oil pressure means the tensioner is pushed harder on the plastic guides which in turn put more pressure on the chains thus wearing the guides quicker .
    todays lesson : change oil pump when doing chains .
    Bug_racer supports the rebellion of the euro revolution
