Haven't used that particular bar. But the rest of their stuff is poor quality. I'd stick to quality parts like h&r
Hi I’m back to looking for a rear swaybar for my bora 4motion. I’ve been trying to find a pre-loved 19mm from a r32, no success.
I only what the rear one, whiteline and
Many sites say the whiteline BWR22XZ will fit bora 4motion, but when I emailed whiteline they say no
Has anyone used this product?
1990 MK2 Golf GTI
Whiteline discontinued the sway for the 4mo, so they told me.
Used R32 or if it fits maybe an Audi S3 sway? May work if u don't want to buy new
Thanks been looking but can’t find 2nd hand, i want to do on the cheap at the moment.
I still have my golfenstine project trying to get Going too.
The bora is the daily
1990 MK2 Golf GTI
The Bora and R32 got the same size sway bars in Aus . Overseas models got euro spec sway bars that are slightly thicker
Bug_racer supports the rebellion of the euro revolution
Really thanks
I thought AU r32 had 19mm bora 16mm
Thanks save me buying the same thing I already have.
1990 MK2 Golf GTI
If you're doing it on the cheap then measure your existing bar and go to the wreckers to find something with similar dimensions but thicker.
Make sure you get all the brackets for the bar as you might have to use them as well.
If you need to use the brackets it helps if you're handy with a welder or have a mate who is.
In the past I've fitted front bars off Mazda's and Mitsubishi's to the rear of my MK1 Golf's - saved me a lot of money.
Paul
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Didn’t think of that approach, just been looking at Audi and vw swaybars
Cheers worth a look
1990 MK2 Golf GTI
Another option is to bolt another 4Mo bar onto your existing bar. You need special brackets but they shouldn't be hard to source.
Looks a bit dumb though.
