Check continuity of the ground wire.
After some help with my 2002 4 motion
It's not firing !
Turns over fine, no warning lights all normal but won't fire up. Yes there's fuel in it.
Throwing a fault code p1049 (NRMA mechanic) which is crank angle sensor fault to ground.
Replaced the sensor and still no go. Checked all obvious wiring, fuses, even swore at it. Battery was disconnected and charged up, no help there ( thought might reset computer)
Any ideas??
Check to see if it has spark, Pull one spark plug out and ground the threads against the engine block whilst still connected to the coil/coil pack and see if it sparks (be careful not to shock yourself).
Next, see if you're getting fuel. Take the supply line to the fuel rail off and open the door and see if it primes with fuel coming out. If not then try starting and see if that makes any difference.
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff| Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
It's probably just a dead crank sensor.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Did you get to the bottom of it?
