Results 1 to 5 of 5
Thread: Bora 4motion Brake Pad Part #
    Jan 2013
    Queensland
    Ive done some thorough searches on the interwebs and can't seem to find the brake pad (Front+Rear) part number for a Bora 4motion 2002
    I suspect it is 1J0698151MKT, but if someone can confirm I would be most grateful
    Erskineville, NSW
    Brakes Direct
    Jan 2013
    Queensland
    Thanks for the heads up Brad.
    Was really hoping to do an order from ECS along with my other stuff, which means I need an OEM/manufacturers part number as they cannot look up non US spec cars.
    Anyone got any idea on part number?
    Erskineville, NSW
    partsbase.org
    Just look up something that shares the same brakes on Ecs.
    Tt gen 1, gli, 24v fwd vr6, 20th all share the same fronts from memory
    Rears should be similar also, caliper is the same for fwd vs awd if that use that vented 256mm disc
