strange, my exact same bearing is starting to let go too. maybe they cop a flogging riding in the gutter and with the weight from the engine...
keen to know the answer to this also if anyone can help please...
As the title would suggest...
I need to replace the front left wheel bearing and from my research, it is a much easier job if a hub with the baring already installed can be purchased as i dont want to mess around paying someone to press the baring in for me.
I have found the R32 part number to be 8N0407613C.
Just making sure that the Mk4 R32/Audi TT Quatro hubs are indeed the same as the Bora 4Mo before i spend the cash.
TIA![]()
No they are different
No idea sorry. Could find one being wrecked somewhere
So rather than risk chance i gave the local VW dealer a call and had them check the part number according to my chassis number and they came up with MF#1J0498625 for the bearing.
So i chucked one in my ECS shopping cart along with Neuspeed dogbone bushings in an attempt to put a stop to some really annoying cabin vibrations.
Now i just need to find someone locally who can get the old bearing out of my hub and press the new one in without charging me an d arm and a leg.
I'm moving to Coffs Harbour soon... not looking forward to finding an honest and reliable mechanic there who i can trust with my cars
I'll report back when the job is done![]()
Bearing for R32 is 8L0498625 hubs are 8N0407253 and 8N0498624
Bora bearing is like you posted and Hubs are 1J0407255AH and 1J0407256AH
Being different parts numbers means there is a difference I do not know what it is.
What exactly are you after ?
Bearing , hub or upright ?
The Bora is the same as the mk4 GTI
The TT/S3 and the R32 are the same upright but the hub is different on the 99/00 TT compared to the later ones with the Bolt for the CV joint instead of the nut .
The control arm on the TT/S3 are the same (incl FWD models) the R32 uses a different control arm bush thats a lot bigger
The TT/S3 R32 all use a different ball joint and Tie-rod as well .
Bug_racer supports the rebellion of the euro revolution
I should add they all use the same wheel bearing
When looking for replacements thinking they were the same as the R32, i came across the hub+bearing pre-assembled combo so naturally i thought i could use it for the Bora. The same assembled combo never came up in my search for the Bora when i found out that they were different. So i have just ordered the bearing and i'll do it the old fashioned way.
