Results 11 to 20 of 22
Thread: bora 2000 problem
    Mar 2011
    rockdale, nsw
    Im sorry my fault. Perhaps word stuffed was a bit to much. The ECU isn't dead but it has to be replaced.
    Thanks for the help Manaz
    without questioning your mechanic. but what makes him think it needs replacing?
    and without the correct tools like what manaz is saying i'd imagine it would be impossible to tell what was wrong.
    Have you had the MAF and things like that replaced before? Is the car doing anything different, temperature guage not sitting on 90oC, blowing smoke or bad fumes?
    May 2010
    Quote Originally Posted by vwbora1 View Post
    I've not needed to yet but if ever I have a problem, I'll be going straight to Golf_Loon at Camden GTI and I live near Blakehurst.
    Especially when it comes to specific VW stuff, like an ECU or electrical issue.
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
    Nov 2006
    Largs Bay, S.A.
    You are better off getting the car scanned by a VW specialist.
    No one here is trying to send you off in the wrong direction. I understand you may feel loyal to a particular mechanic that you've seen for many years, but the car can reveal many faults via the software a specialist uses to interrogate it. It is not something your average mechanic would have access to and it will save you a lot of time and money tracking down what could be one of many things.
    Check the Recommended Repairers and Parts Suppliers thread for someone near to you. They are all reasonably priced and are recommended for a reason.
    Best Wishes.
    Apr 2008
    What possible reason is there to replace the ECU unless it's dead (partially or fully)? It could just be throwing fault codes (it's meant to do this) which need clearing (need the right tools to do so).
    Changing ECUs is not a simple or cheap matter...
    Nothing to see here...
    Aug 2007
    Yeah agreed, be interested why the ECU has been called, not questioning the diagnosis as it could be, but interested. Some motors have a power steering switch that signals the ecu to idle up, this is indeed something that can be measured with live data.
    Keep us posted
    Jmac
    Alba European
    May 2009
    I'd definitely get it scanned by a VW specialist... doesnt have to be a dealer. I'm saying this because I set off a fault code when I was playing with fuses and I knew exactly what it was (i triggered the airbag fault because I forgot to put it's fuse back in and started the car). When I took it to a normal mechanic for pink slip he scanned it and told me it came up with ECU damaged on his diagnosis machine. Took it to a VW auto elec and scanned it and confirmed I was right and it was just a tripped code, reset it and all fine. Peakhurst shouldn't be too far to drive, that's the VW auto elec I went to, for the sake of the $25 cost to scan it you could very well save yourself an expensive exercise in replacing stuff that doesn't actually fix the issue.
    Project Hairdresser car DIY build has begun...
    '96 Mirage Track car: BC RM Coilovers, 294mm Galant VR4 Brakes, 5 stud conversion, 16x8 Forged Rays MS01S, UR 23mm sway bar, UR Strut Braces, Evo 5 Recaros, MR Lancer electrics interior conversion, Engine + Exhaust in the works
    May 2010
    VWbora1, If you like I can scan it free of charge for you using VCDS. I'm only a couple of suburbs from you.
    Feel free to PM me to make a time.
    Camden, Sydney
    Bring it to Campbelltown. We will give you a free 5 minute diagnosis and scan.
    We only work on VWs and Audis and I would also question the diagnosis of ecu. It wouldnt do the things you describe. Even if your man gets another ecu, he wont be able to code it to make the car run.
    Its the old thing, pay a specialist who is familiar with your car a fair price to fix it, or pay someone hours and hours of scratching their head to try and work it out.
    Up to you, see you soon I hope.
    Mar 2011
    rockdale, nsw
    Boys thank you very much for your input. The car will be scanned by VW specialist tomorrow. Will let you know how it went.
    Speed and Golf Loon Thanks guys, will do if it doesn't work with my mechanic.
