Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Boost Leak
  1. #21
    Munno Para West Adelaide
    So I decided to change mine back to stage 1 and have to do this because it doesn't have strong acceleration at all.
  2. #22
    Jan 2011
    Gold Coast, QLD
    I forgot I had my own thread for boost leaks. Copied my text over.
    I think I will do a comprehensive boost leak guide after this, I'm having the most frustrating experience.
    Did another boost test. Moar boost leaks identifed!!!
    N75 to turbo actuator.... Smallest leak but it's still metered air leaving the system!
    Of bigger concern, the brake booster vacuum line has been dodgily patched up in the past, and it's leaking. Tbh I can't believe I haven't noticed this on the past. This is kinda concerning since brakes are nice to have.
    Other than that it's holding pressure fairly well.
    How loud should the noise of air passing through the block be. Mine is fairly loud, kind of sounds like another leak.
    Boost leak test was to 20psi, so fairly happy.
  3. #23
    Jan 2011
    Gold Coast, QLD
    All boost leaks accounted for and fixed!!! Holding a steady 20psi during boost test. Time to move onto the fuel pump upgrade 😁😁😁
    *High five* anyone? Anyone?
  4. #24
    Mar 2017
    Did u get a new booster line? I have the part number if you need, had to replace mine, had a pretty dodge patch up aswell
  5. #25
    Jan 2011
    Gold Coast, QLD
    I did a dodgy patch up to fix the ultra dodgy patch up 😀
    Yes please! I would like to know the part number. I was looking on etka but could not work out the correct one for the agu.
    What was the cost?
