Originally Posted by
Sirocco20348
I logged various blocks in vagcom yesterday and one value that was highlighting concern was the n75 Duty Cycle.
It had no idea what it was doing! Most the time it was 0%!! Which means valve open and the car relying on wastegate pressure for boost. I will post logs when I get a chance.
How much psi would be required to open the wastegate?
This might explain the whistling noise being the Wastegate opening slightly under pressure.. maybe?
I might see if someone has a spare n75 to test out.
Sent from my Nexus 5 using Tapatalk
