Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Boost Leak
    Jan 2011
    Gold Coast, QLD
    Boost Leak
    Hey guys,
    Edit: I might give some context to this problem. I installed my front mount intercooler and had the system smoke leak tested by Alba European. He confirmed that there are no boost leaks and the car felt strong (20psi), butmade a funny whistle noise at full boost. I contacted Jimmy and he ensured I had no leaks, so i thought it must be air passing through the new pipes and created a whistling noise. (??)
    Anyway as the weeks went on I went from a max boost of 20 psi to a max of 18psi and then a max 15 psi last week! Which made be want to action it. So i thought I must have a boost leak? Maybe?
    Boost test:
    • I fabricated up an attachment to connect into my TIP with a nitto attachment on it to connect to an air compressor.
    • I set the air to be regulated to the minimum setting.
    • I also unplugged the hockey puck and plugged the hole to avoid pressurising the sump.
    • Do i need to do anything else?
    Anyway I start the test, and I get a really high pitch whistle happening!!!! Similar to the sound i hear at full boost but a mega version.
    I freak out and then unplug the nitto coupling which makes the big whoosh sound.
    https://youtu.be/2821FhrB3lM
    Please watch and if I am doing anything stupid please let me know....Does it sound like a boost leak somewhere?
    I'm scared to do the test again in case I'm damaging something.
    How do you regulate only a certain amount of air into system? Eg. I only want 1 bar of pressure for the test.
    Aug 2016
    compressor has a regulator on it?
    theres a youtube video that goes for 12 mins. thats good..mexican dude.
    also smoke test works good-could get a mate revving up the car for pressure...
    oil cap off..should keep things safe..plumb a guage into the pvc tube you made for the tip should be good..worked for me..dv
    yours sounds like a split in the hose on a guesstimate..bitch of a thing and annoying as all hell
    all the best
    DEEP POCKETS NEEDED
    Jan 2011
    Gold Coast, QLD
    Yeh no regulator which is obviously not ideal which is why I set the air pressure to minimum.
    And yes oil cap was off, I forgot to mention that.
    I'm pretty sure this is what I need. Can you confirm?
    Air Pressure Regulator Relief w/ Gauge Hose Quick Release Compressor Fitting 1/4 | eBay
    I'll make sure my boost leak test is 100% accurate before proceeding.
    Sent from my Nexus 5 using Tapatalk
    Aug 2016
    yeah rok that do it!
    taper pressure up in lots of 5 to be safe if your paranoid..i would just smash it with air and zone in on that fkn farting noise personally,least you know its there and not in your head lol..these rides do your nut in!
    DEEP POCKETS NEEDED
    Jan 2011
    Gold Coast, QLD
    Ok I ordered that to help out.
    I have noticed my turbo inlet pipe does not have a clamp on it.... i guess the coolant hard line keeps it on. The pipe is under vacuum, should I put one on?
    Aug 2016
    wouldnt hurt
    DEEP POCKETS NEEDED
    Jan 2011
    Gold Coast, QLD
    I logged various blocks in vagcom yesterday and one value that was highlighting concern was the n75 Duty Cycle.
    It had no idea what it was doing! Most the time it was 0%!! Which means valve open and the car relying on wastegate pressure for boost. I will post logs when I get a chance.
    How much psi would be required to open the wastegate?
    This might explain the whistling noise being the Wastegate opening slightly under pressure.. maybe?
    I might see if someone has a spare n75 to test out.
    Quote Originally Posted by Sirocco20348 View Post
    Call me when you have a break mate.
    Jan 2011
    Gold Coast, QLD
    Ok so I upgraded my vagcom cable and it logs much better now.
    As expected n75 duty cycle stays maxxed at 99.6% throughout the rev range. This indicates that I do have a leak.
    I'm awaiting my air pressure regulator to arrive to hone in further to find out what the hell is going on.
    I ordered a new n75 anyway, I'll place it on the shelf until this one fails completely.
    Sorry i haven't called back. Been so busy at work. Call me tomorrow. It's looking reasonably quiet ATM
