Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: Boost guages
  1. #31
    Yeah - i'm gonna source a mate to give me a hand to run the tubing through. I can't wait to see what kind of boost I am actually running.
    When you cut into the vent, how did you secure it in place?
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
  2. #32
    Feb 2008
    New Zealand
    Quote Originally Posted by 99gti View Post
    the gauge i assume?
    the gauge was tightly wedged in there! and nothing was holding it in it was just wedged in!
    when cutting the grille you gotta take your time other wise certain slats just dont line up heres a basic idea of what you have to do!
    You need to remove the left and right adjustable slats behind the horizontal slats and slowly cleanly melt your way thru slat by slat without damaging the top and bottom slats to much...
    oh by the way you need to remove the vent from the entire pod (the pod is the vent surround that houses your head light switch and yada yada)
    the next part is the right bitch you gotta take it easy to not **** it up
    but you need to put the any fittings on to the back of your gauge to gauge what you have to cut out of the back of the pod to make it all sit in tight..
    i had a square brass fitting on the back of my gauge which allowed me to cut a opening just small enough for the cube brass fitting to squeeze in to and hold everything in place!
    (you have to remove the entire thing from the car like in my example photo) i should have got some photos from the back of it to show you i might try do that tonight if i can see my old car)
    now!
    upon installing the main pod back in to the car you will have to slowly start cutting away at the annoying peices of plastic supports that sit behind it (but block the gauge and pod being inserted back in!) it takes time but end result is its custom.. its your own doing.. and you can actually lay claim to making it yourself...
    also!!!
    when i ran my boost line i ran it up the drivers side of the engine bay following the bonnet release cable in to under the windscreen cowling and thru the rubber grommet on the wiring loom box thingy (its a white annoying plastic box thing under the wiper motors you gotta remove em to get at it and do it properly!!!!)
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
  3. #33
    Thumbs up for that Thank you!
    I'll make sure I get lots of photos when I do it and with your discriptice write up I'll add it to the FAQ's. I can't wait for it to arrive now.
  4. #34
    Jan 2008
    Melbun
    anyone know of any gauges that read up to 40psi? no vacuum reading needed. its for my tdi.
    2x Caddy, 1x Ducato
  5. #35
    I think the autometer cobalt series goto to 30 or 35...
  6. #36
    Jan 2008
    Melbun
    i think the tdi stock peaks around 35psi or something... maybe i should look into industrial gauges meant for trucks
    2x Caddy, 1x Ducato
  7. #37
    Quote Originally Posted by Mischa View Post
    I was under the impresion it was only like 15-18?
  8. #38
    Jan 2008
    Melbun
    iuno but this i from mik's boost gauge install so i would guess the gt runs more boost than the c-line? http://www.vwwatercooled.org.au/newf...75&postcount=9
    2x Caddy, 1x Ducato
  9. #39
    Jul 2005
    Newcastle, NSW
    Well you know what I chose, check out the guys at 42 draft designs, they looked after me and know the TDI.
  10. #40
    Sep 2005
    Maroubra Beach
    Quote Originally Posted by HitmanR32 View Post
    Hey guys i stole the SWG motorsport idea and took to my spare Vent with a Heated knife..
    at which point i installed my New South Performance Gauge! this is a old post from my Forum so excuse it but i have just C&P'd for your information
    I can highly reccoment the NSP gauges.. i think imho they are the nicest of the lot! and a very very close match!
    ----!!Begin C&P of Old Thread!!----
    Well finally found a Perfect match guage for my car that has proper EL Lighting in "Indigo" colouring and a similar font..
    So I had to decide where to put it so it didnt stick out to much and didnt get in the way to much
    So after seeing Vent side pods for sale on the net i thought hmm ill do that and buy one..
    After falling over at the price of 260 New Zealand Dollars Landed i thought Flip that idea ill make my own
    So I tootled of down to a Reputable VW Parts dealer "Platinum VW Spares" and purchased myself a Surround and Vent for the Driver Side
    Measured out how I wanted to put the Guage in where I wanted it and how i wanted to sit grabbed a sharp but old knife and grabbed my propane blow torch and melted out the where I wanted the Guage to Seat
    worked a treat here are the results
    The 42DD gauges are utter**** and have been a complete let down they ****ed up FIZZ's order 3 TIMES!!!! and the illumination wasnt what they claimed it to be
    the NSP and SWG gauges have nice even illumination!
    have u got a link of where you bought your gauge from and how much it cost?
