Results 1 to 10 of 12
Thread: bolts and washers in australia
    May 2015
    hi all
    just wondering if there's any other (possibly less expensive) option to get one use bolts (sub-frame, water pump etc) and washers from other than going to VW/Audi themselves?
    I find it hard to swallow buying a $5 washer to pay more than triple just for postage
    Dec 2008
    Sydney/Canberra
    Most of the single-use stuff you can actually re-use.
    Bolts from VW aren't that expensive, considering they're specific to the job.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2006
    Adelaide South Australia
    When I changed the timing belt on our previous 6N2 Polo, there were a number of bolts that were single use only stretch bolts. When I tried to buy them there were none in Aust., had to go on back order. I figured that I was one of the few people who worked by the book & that most mechanics just reused them. When they arrived I thought the price was very reasonable. I am currently restoring a Lanz Bulldog & any high tensile or fine metric bolts from the specialist fastener suppliers is quite expensive.
    Numerous Mk1 Golf diesels
    May 2015
    Thanks jets
    I might give them a buzz tomorrow to sort it out of there was a wait on them for you...
    What would be the con if I weren't to replace? How dangerous is it REALLY?
    Gosford Central Coast NSW
    Quote Originally Posted by IanPGonzaga View Post
    Thanks jets
    well it depends what the bolts doing.
    There are a lot of single use TTY (torque to yield) bolts on VW cars. There are also a lot of bolts which are called single use but which are not torque to yield.
    You can usually tell the TTY bolts by the torque spec, which will be "torque to Xnm, then another 180degrees, or something like that. But thats not foolproof way to tell by any means.
    I buy bolts from the dealer pretty regularly. They are not actually expensive, especially if you can pick them up. It also helps to find a friendly dealer parts desk that will give you trade.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jul 2007
    Brissy
    Shoot a PM to Parts@KDVW
    Forum sponsor, Kevin Dennis VW parts department.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    May 2015
    I'll try a couple dealers and see what prices I get and also PM Kevin
    I rang up for 75w90 GL4 gearbox oil the other day... 1 L = $80. F that
    Thanks guys
    Dec 2008
    Sydney/Canberra
    Yeah, don't buy oil from the dealer.
    Unless it's Haldex coupling oil, because nobody else makes it.
    '01 Beetle 2.0
    May 2015
    Oh I sourced that from overseas too. I was thinking the price would also be ridiculous if bought from dealers. Do you remember how much it was for future reference? Haldex Oil and filter?
    Erskineville, NSW
    depending on the bolt - you could replace them with grade8 standard bolts from the fastener suppliers. Then you have to do a bit of thinking about what to torque them to. Possibly use a drop of loktite too.
