Results 1 to 10 of 13
Thread: bloody passenger door..
    Aug 2011
    melbourne
    everyone knows they are a problem, but the first thing people say to so is open the door so you can access etc etc...
    my front passenger external door handle does nothing, and the internal door handle makes the door pin go up and down, but doesnt allow the door to unlatch.. makes no noise other than the door indicator pin moving up, which then falls again as soon as you let go of the inner door handle....
    any help?
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
    Mar 2010
    Lesmurdie
    IIRC you should be able to remove the external lock which gains you access to the mechanism for either the door lock or pull.
    I.e
    Pull on the exterior door handle - with the door handle in this position, pull on the lock cylinder. It should slide out without much trouble. Set the lock cylinder aside.
    taligentx.com: Passat - Dlm 08 lock...
    There is a cable hooked into the side of the exterior door handle. The cable can be positioned at various points along the handle. Note the current position of the cable and release it from the handle.
    taligentx.com: Passat - Dlm 10 exterior...
    Might even solve the problem. Let us know if you need more help.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Aug 2011
    melbourne
    ah cheers, i figured id have to go internal door handle. so had it half out and was worried id snap it cos it just wouldnt come free.
    ill have a go with that method and see what i can find. cheers.
    Jul 2007
    Brissy
    The lock cylinder is held by a bolt only accessable with the door open.
    Have you tried turning the key in passenger door a little further than normal? normal turn activates electronics, further does the manual unlock.
    Aug 2011
    melbourne
    Sorry guys, forgot to mention I have factory central locking as its an 02. So I can't take out the barrel, nor use the lock to manually open it.
    Newcastle, NSW
    Quote Originally Posted by leighaus View Post
    Sounds to me like the dead lock inside the actual lock mechanism has 'clicked-in'. Trouble. Best advice I can give is to start googling/vortex searching with those 'dead lock' terms involved.. Sorry I can't be more help.
    Dark Grey Mk4 Golf, 1.8T GTI conversion, APR stage 1, stock air intake, FMIC, 3" to 2.5" Exhaust, FK AK Street Coils, Black 18" (Avant Garde M310's ?), tinted tails, ...
    Mar 2010
    Lesmurdie
    Quote Originally Posted by JustCruisn View Post
    Oh yeah now i remember its the pain in the ass one that keeps falling into the door. Would make sense as well.
    Now im really clueless as to what you can actually do. Apart from what you've done which is remove the interior door handle and try that. I think you might have to do as kenbot said
    Jul 2007
    Brissy
    If you remove the cover where the lock barrel would normally be, what do you find? I know some cars with remote locking just have a cover and there is actually a lock under the cover - worth a look I guess
    Mar 2010
    Melbourne, VIC
    this works for me (I currently have 2 dead locks at the moment and its driving me insane):
    sit in the drivers seat and hold the central locking button on open and keep it pushed down, then reach across and open the door using the door handle at the same time, the button should pop up and stay up and you can open the door
    let us know if it works
    alternatively if all else fails paint a southern flag on the roof and climb in the car dukes of hazard style
    Newcastle, NSW
    Quote Originally Posted by vwsport View Post
    Hahahahahahaha, Yeeeee-HHaaaaaaawwwwwww!!!
