Results 1 to 10 of 15
Thread: Black smoke! Help needed??
    Sep 2007
    bossley park
    2.0L golf sport 124,000kms
    Hey guys,
    When i bought my car some 20,000km ago i replaced the oxygen sensor as it was stuffing up and black smoke was blowing through the back. Lately on random days the same thing happened twice (about 2 weeks gap), but when my brother hooked it up to the vag program it was coming up as the oxygen sensor again but then it was saying it was fine. So we assumed it was fine and it was a random occurance
    Today in the morning it stuffed up again and was blowing black smoke and burning bout 2.8L/hr at neautral at the lights. Later on in the day it was fine again burning 0.9L and no black smoke. My brother thinks theres something wrong with the computer or ecu or the earth might be damaged, meaning that its not sending the right signals to the oxygen sensor hence the bad burning of fuel.
    any take on this guys? Is it an electronics problem?
    cheers
    Sep 2007
    bossley park
    any take guys?
    Most likely electrical. HAve a GOOD look at the wiring above and on the probe. It could be rubbed through and shorting to earth.
    Sep 2007
    bossley park
    ill take a look t it today when my brother gets back home. im guessing if its shorting the earth, the sensor isnt getting the right signals and the mixtures are stuffing up?
    Sep 2007
    bossley park
    does anyone know any people who specialise in volkswagen electronics?
    Sep 2007
    bossley park
    we hooked it up to vag-com just now and its coming back as oxygen sensor no signal..
    That's a better description to work off.
    That would look to be a duff probe again. I'd be checking for shorts to ground if there's nothing coming out of the probe. As I said in your other thread, have a look at the measuring blocks.
    Guest Guest
    Coolant temp sensor
    Quote Originally Posted by flynhigh2007 View Post
    Hey guys,
    cheers
    It will be your coolant temp sensor out of spec making your car put more fuel in (black smoke) and freaks out the O2 sensor causing a "fault" but CTS is at fault common problem check if you CTS is black in color these fail all the time the new ones should be green but even they fail too
    Jan 2009
    Anglesea,victoria
    Quote Originally Posted by VWweirdo View Post
    where is the sensor? im having a similar problem with my car, geting a black watery liquid on the floor and the car is also running rich, id really like to stop this happening as its whenever the car is running not just odd days like in the OP's case.
    Sep 2007
    bossley park
    More info:
    Its a new sensor throwing out an error code P0134,we then cleared the error code and the error comes back even though the measuring block is showing the sensors changing voltages.
