Results 1 to 5 of 5
Thread: Best wheel alignment in Melbourne
    Hi guys,
    I'm just wondering what experiences you have had with wheel alignments.
    Where the best places are to have a wheel alignment in Melbourne and what stores to stay away from? (Costs will also be helpful)
    Just a quick question, are all front wheel drive Mk4 golfs only front wheel adjustable? Meaning only a two wheel alignment needed?
    Thanks
    Apr 2011
    Berwick, Victoria
    Quote Originally Posted by PrOxIMPURE View Post
    Front has toe adjustment and the slightest amount of camber adjustment (say like .05 deg).
    Rear has some give with the bolts - can be used to equal toe a bit or move the beam left/right. You cannot change rear toe individually. Cannot change rear camber. (refer to camber shims, can be used to fix toe upon lowering an MK4)
    Some good info:
    VWVortex.com - MkIV Camber plate list
    Quote Originally Posted by MCiN7 View Post
    Some good info:
    Thanks for the information !
    If you are not having excessive toe or camber wear on the rear I wouldnt bother touching it.
    front is next to no camber adjustment. just toe to correct really
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2007
    Brissy
    Given the lack of adjustment on these cars a specialist is not really warranted.
    Unless you are seriously low or have some specific settings in mind, Kmart is pretty cheap.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
