Results 1 to 6 of 6
Thread: back window wipers
    Jun 2009
    Altona, Melbourne
    back window wipers
    any one know how to change the back wipers or know where to get the rubber for them, it just cost way to much to go to the dealer to change the wipers! just not worth it.
    Aug 2007
    Perth WA
    Standard replacement blades from supercheap et al. 6 or 8mm I think. Just slide out the old one, slide in the new one and cut to length. Don't think any of the Mk IVs have aero wipers on the back as standard, only on the front.
    '04 BMP MkIV R32 #144
    search getnew
    Apr 2008
    Quote Originally Posted by geoff_gti View Post
    Yeah it's easy as pie mate.
    7 bucks for a generic blade from Repco or similar, just cut down to size. Same for the front (don't know about Aero ones).
    FYI they're the smaller sized blades - front and rear.
    2000 Mk IV GTI
    Aug 2007
    Perth WA
    Front aero wipers can be 'refurbished' without having to pay an arm for a new set. See here
    search getnew
    Jun 2009
    Altona, Melbourne
    yeah i changed the front ones when i read that thread! that was awesome as but not the back ones only, but if's as easy as you guys say it is then i'm all good, i hear some where that the arm holding the blade is aero. but we'll give it a go. thanks guy!
    Aug 2007
    Perth WA
    if the back wiper is a solid rubber unit like the fronts, then they're the aero design. if it looks like a normal metal wiper arm with the clips, then slide in slide out should do it
    search getnew
