Standard replacement blades from supercheap et al. 6 or 8mm I think. Just slide out the old one, slide in the new one and cut to length. Don't think any of the Mk IVs have aero wipers on the back as standard, only on the front.
any one know how to change the back wipers or know where to get the rubber for them, it just cost way to much to go to the dealer to change the wipers! just not worth it.
'04 BMP MkIV R32 #144
search getnew
yeah i changed the front ones when i read that thread! that was awesome as but not the back ones only, but if's as easy as you guys say it is then i'm all good, i hear some where that the arm holding the blade is aero. but we'll give it a go. thanks guy!
if the back wiper is a solid rubber unit like the fronts, then they're the aero design. if it looks like a normal metal wiper arm with the clips, then slide in slide out should do it
search getnew
