i had a similar problem when i pick up my R, if you went to open the car with the fob it would open then lock straight away, and if you used the key the same thing would happen. so you had to turn the key in the lock and open the door and press the fob button all at the asame time, which would open the car and set the alarm off. good fun!![Banana](https://www.vwwatercooled.com.au/forums/images/smilies/emo_banana.gif)
i took it to an auto electrician who said that a solder had gone in the driver's door- problem solved for pretty damn cheap.
sounds like a similar problem- can you get into the car at all?
black mkIV .:R32 #001/200
04 black new beetle turbo
matt black 1970 beetle- low n slow!
