Results 1 to 10 of 15
Thread: Significant rear camber - are the rear springs sagged?
    May 2017
    I have a MKIV 2004 2.0 Golf with the rear beam suspension. As far as I can tell the car is stock standard (not lowered) however the rear has noticeable camber and is scrubbing the inside of the tyres.
    I checked to see if the stub axle has been shimmed (no) and the springs look like the originals.
    I'm thinking the rear springs are sagged and that has caused the camber.
    Has anyone experienced this on the rear beam suspension?
    Thanks
    Trash Hauler
    Jan 2011
    Gold Coast, QLD
    What psi do you keep your tyres at and do you rotate them every 10k kms?
    Sent from my Nexus 5 using Tapatalk
    May 2017
    Quote Originally Posted by Sirocco20348 View Post
    Tyre pressures are 28 PSI
    The car has 139500 kms and i have had it for 2000 kms so have no idea how long since they have been rotated but doesn't look like they have ever been rotated
    BMW 330i M Sport 2006
    Golf MKIV 2.0 Lt 2004
    Jan 2011
    Gold Coast, QLD
    28psi is way too low. They are under inflated and hence the noticible wear on the inside. VW says 28psi is recommended, but it's purely for comfort purposes. I would pump the tyres upto 34psi at a minimum.
    Jul 2007
    Brissy
    28 is not enough.
    Generally the rule is, 2 x rim size + 2
    15inch = 32
    16inch = 34
    17inch = 36
    18inch = 38
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    May 2017
    Thanks for the advice - will up the pr sires to 34.
    i will post a pic tomorrow to show the camber - any advice is appreciated.
    cheers
    TH
    May 2017
    Noticed the same on the Golf we have, regarding the camber, ours is 2003 model.
    Would be interested also to find out about this.
    There is anywhere from 1 and 1.5deg on the rear as standard.
    Keep in mind. Toe in Or out is more often the cause of wear then camber.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Dec 2008
    Sydney/Canberra
    I'd have thought being a beam axle, the camber would be relatively constant.
    Typical ride-height changes wouldn't affect it too much, if at all.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2011
    Gold Coast, QLD
    Yeh beam axle makes the camber static.
