Results 1 to 10 of 15
Thread: Anyone knows what this is?
    Nov 2008
    Sydney, Macquarie Park
    Question Anyone knows what this is?
    Found it on the floor below the glovebox. Any ideas of where it should go and what it does?
    '01 VW Bora V6 4motion - gone
    17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
    Yep. because mine came out the other day, but on the drivers side.
    they are part of the chair. think its to do with the leaver to raise/lower the chair? mine still works but is just a bit weak feeling. At least that's what i think it is, Silver dub posted about it a while back but i don't remember what the solution was...
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Northern Beaches
    yeah i have found the same spring thing as well on the floor. i think it's off my seat for the forward and back movement.?
    Apr 2008
    It's a spring designed to keep the underneath of the car seat "taut". Once they fall out, they just keep falling out, putting it back is fairly pointless.
    Nothing to see here...
    Nov 2008
    thanks for the replies guys. weight saving!
    Quote Originally Posted by Manaz View Post
    Doesn't do any damage not being in there?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2008
    melbourne
    Mine fell out about 8 months ago and i started my investigationing. Basically it helps in the raising and lowering of your front seats. If you raise the seat whilst your not sitting in it you wont notice a difference but if you sit in the seat and try and raise it, it will be harder to do so. The reason they come out is because the tiny tab on the bottom of the chair in which holds one end of the spring has broken off. It's not worth fixing because you will have to replace your whole seat frame and it cost hundred's of dollars to do so, also then it is bound to happen again in the distant future. Vw obviously didn't make the tab strong enough in there designing stages.
    May 2007
    Moonee Ponds
    Cool, I have wondered for ages, mine came out and Volkspower said it wasnt needed It was rattling like a mofo driving me up the wall
    Quote Originally Posted by Silver dub View Post
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    Jul 2007
    Brissy
    The tab is made of die cast. The same thing used to make model cars.
    If you look around on the floor you may find the little bit of crappy metal.
    Apr 2008
    I wasn't aware that my passenger seat had height adjustment - you learn something new every day!
    Any idea of how the mechanism works (I'm curious now as to whether I should organise to have a tab welded back onto the seat...)
