Firmer than stock, but definitely not what I would consider uncomfortable. You must realise that everything is a balance/compromise. If you want better handling, you will have a firmer ride. I consider the V1s or Hicon GTs to be the best compromise.
That's not entirely true. If you have them wound up to a point that the spring is pre-loaded, the ride will be harsher. If you lower the car, it will soften up.
Another thing that I tell people is to give the dampers about 2,000 km to bed in. If you think they are a little firm brand new, let them settle and then make your decision.
I went for a ride in Pierre's old red Mk4 GTI when he still had it, and it was low. The ride in it was quite good, and that was tucking 19s with KW V3s (which are firmer than the V1/2s).
At the end of the day, they ride a lot better than stock dampers with King Springs....
