Results 1 to 10 of 13
Thread: Anyone gotta spare coil pack -1.8t agu
    Aug 2009
    As above. It's the weekend and no where's open so I thought I'd ask the question. Anyone gotta spare??
    Part number is 085 905 105
    Cheers.
    PS if you have a missfire, it's more likely to be the ignition amp in the airbox or a duff plug in my experience.
    Aug 2009
    Thanks dude. I'll send him a message.
    Racq came out and was definitely a coilpack. (he had a coil pack tester)
    Plugs are no more than 10k old and they're platinum plugs. Should last longer than that.
    I thought it was the ignition module. Hmmm.
    I need to buy vagcom
    Anyone wanna sell one?? Haha
    It wouldn't tell you anything. Disconnect the bad coil pack, at tickover, then swap it with another and try again. If the amp has gone it'll be the same cylinder effected. If the coil pack has gone the miss will move.
    I am still leaning towards the amp from personal experience.
    Aug 2009
    problem is i dont have a coil tester like he did (it'd just run the same as it is and move cylinders without me knowing haha), hmm should i do the ignition module before the coil pack?!!?!
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    If you have a bad coilpack and disconnect it the engine note won't change. For example lets pick #4. You swap coilpacks 1 and 4 around then run it again. This time disconnecting the new #4 cause the engine note to change. Proving coilpack in #1 to have been the problem.
    If disconnecting the new #4 made no difference the fault must be further up the line, ie the amplifier.
    DIY test of power output stage/ignition amp module N122 (long & BWW) - AudiWorld Forums amplifier testing procedure.
    Aug 2007
    i sure do have one, but i would have a read of my pm
    Jmac
    Alba European
    Aug 2009
    all fixed now. car's running better than it was. ended up replacing the ignition control module.
    thanks for the help fellas, so lucky theres so much info on our cars!
    Aug 2007
    I knew my coils would keep there pile of dust on them.
    Good to hear
    Jmac
    Alba European
