So for those of us who are fairly new with the Watercooled scene, why would you get these instead of buying the replacement mounts you can get for 1/3 price and install them yourself to the existing dogbone?
bump 7 left to buy!
2000 Mk IV GTI
cause most the time the ones you fit your self are to hard, these density line mounts are the ducks nuts as far as a whole unit goes, and they are 1 of only a few who make the side mounts aswell.
mk4 the mods begin for round 2 hahahha
I know that the OEM mounts use a very soft rubber insert and deteriorate.
My question was besides the ease of installation, why would you spend $100 on this as opposed to just replacing your OEM dogbone with new rubber/stronger inserts? I mean, the arm is basically the same, but it's the rubber bush that is different, right?
2000 Mk IV GTI
cos theyre softer than other aftermarket solutions so have less chance of causing extra vibration
correct but thats how they make them unfortunately u have to buy the arm and bush together. If i could buy just the bush i would but INA are the only company that make a 50a rated bush whilest the other companies make inserts rated at 70a.
Its still ok for $100 u get a new arm where tuners like APR sell just the bushes at $100
Do these things need to be replaced regularly?
and the after market ones you fit yourself are like $60.00 or was when i bought some. $100.00 i thought that was a good price man times are tough.
