Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Any other early Mk4s here with Cobra keyless entry remotes?
    Apr 2013
    have the same remote system, any ideas on fixing the missing buttons indicated below?
    Jun 2008
    Sydney, The Hills
    Quote Originally Posted by JustCruisn View Post
    Sounds like its a power issue. It may be getting switched acc power when it needs a constant.
    Would that explain why it would open but not lock? Might run a wire from the battery directly to the unit as a test and see how i go!
    Quote Originally Posted by kdog View Post
    All I can suggest is buying a new PCB from eBay or similar. Like this one? You could try programming the new PCB to your system, and if that doesn't work, transfer its buttons to your existing PCB (if you're handy with a soldering iron...).
    Man I wish I was more useful with electrical stuff.
    Jul 2009
    Geelong, Victoria
    try VW for a new remote, i bought a complete kit within the last 6 months
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Apr 2008
    I had same unit in my VW Golf MK3 VR6.
    Bought from VW dealer in Brisbane more than 5 years ago and still working with NO issue.
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
    Dec 2013
    Some further vw mk4 questions....
    Your post it's was very helpful to me to fix my alarm... Thanks!!
    Would you, by chance, know how to get a passenger door out of safe mode? The button moves with the key and inside handle, but never gets to unlock.
    I'd pull the door apart to resolder the broken cold joints in the actuator if I could only open the damn thing...
    Thanks for any help here.
    -Neil
    Quote Originally Posted by Jmac View Post
    This is the Votex keyless upgrage they made exclusively for VW , the module was normally fitted inside the drivers door and ustilised the green and grey central locking wires coming from the lock module. Any we fitted went there, made it heaps easy to fit and terminate
    See how you go
    Jmac
