Results 1 to 10 of 15
Thread: How to tell if dogbone is dodgy?
    May 2009
    Perth
    I'm having the occasional clutch on hard accelerating and braking. It doesn't happen every time.
    I haven't had a chance to get under the car and have a poke around. I intend on renewing suspension bushes etc before doing any mods but wouldn't mind starting with whats broken and given that there are some group buys going on at the moment I'm tempted to jump in with those.
    Can you elaborate what your problem is. A new dogbone mount would tighten up engine movement for sure.
    I have the softer of the Black Forest Industries mounts on my S3 and it's pretty good. Not too many vibes in the cabin at tickover.
    I have the stiffer one here too but never fitted it yet.
    Apr 2008
    What you're looking for is damaged/frayed rubber in the dogbone mount.
    If it doesn't look like this:
    With the rubber bits (the black bits in the image) all looking clean and tidy.
    If they're tatty with torn edges, pieces missing, or the rubber seems uneven where it sits between the metal parts, then it's possible that you'd want to replace the bushes anyway.
    I'd be surprised if the metal parts were damaged unless the rubber had perished entirely and there was metal-on-metal contact (that'd be noisy)
    Irrespective, the INA Dogbone mount also improves on the stock design by having tougher bushings in it. There's a little more transmission of vibration into the cabin, but it's barely noticable in the street version (particularly in a 5+ year old vehicle), and the whole engine/gearbox/drivetrain combo just seem tighter and better linked together with it in place. It's hard to describe, but it's definintely noticable - less hesitation in the work the engine does being applied to the driven wheels is probably as close as I can get.
    Nothing to see here...
    May 2009
    Perth
    whoops...typo
    it's a clunk not a clutch and i can feel it a little through the pedals. First time it happened on braking and i thought maybe it was just a pad seating issue. But if you accelerate hard it does it sometimes too.
    Apr 2008
    Quote Originally Posted by IanJ View Post
    whoops...typo
    Clunking is generally a failed bushing in my experience. Where, that's another matter... Getting underneath and having a good look will help you discover where it is!
    May 2009
    Perth
    Thats my thinking too....nothing for it but to get it up in the air and have a poke around.
    Dec 2007
    Auckland, New Zealand
    Check the upper gearbox mount as well as the dogbone mount. I'm having the clunking issue as well and found it to be the upper gearbox mount. Need 2 order new mounts
    1999 Golf GTi - SOLD
    2005 Golf GTI (2 Door) - SOLD
    2014 Octavia RS400 Combi
    1997 Golf GTI (Daily/Track Hack)
    Jun 2008
    Ringwood, Victoria
    I replaced the bushes in mine with the Harding Performance ones through Dean at Volkspower, made a HUGE difference, but also increased cabin vibration which i'm either used to now or it has softened off a little after a few heat cycles
    If you're after a cheaper alternative, have a look at Dub Addiction, they're on sale there a fair bit cheaper. In my opinion, unless you plan on spending a whole lotta time under your car looking at your torque arm (dog-bone) and shining it up all nice, just stick with replacing the bushes, it only takes 3 more minutes than replacing the whole arm
    Jul 2007
    Brissy
    Dogbone replacement take all of 15minutes, less if you have a hoist.
    I paid like $70 for ARP 90 duro bushes, that was only the end bushes, not the round one.
    The INA GB for $99 bux is a bit much IMO, and what would you do with the spare metal bit anyway ?
    OP I have the stock mounts somewhere in the garage, make me an I can't refuse.
    Dec 2007
    I ended up doing the same as this guy did on vortex. Basically i used the rear dog bone bushing from the bfi stage 1 set combined with the front oem bushing. I found the BFI stage 1 a bit rough for my liking, but the above combination seems to be a good balance. It's soft enough, while still keeping my downpipe from rubbing on anything. I'm guessing the oem bushing might wear out a bit quicker maybe, but they aren't hard to come by.
    http://forums.vwvortex.com/zerothread?id=4328630
