Check this out guys:
VWVortex.com - Your Haldex Works Powertrak Insert: Review
Sent from my SM-G930F using Tapatalk
That thread further feeds my scepticism. I might go rear sway first.
Agreed. I did have some concern regarding the internal clutch pack, the whole thing just sounded a little too good to be true.
I did however find the below which sounds good.
http://www.unitedmotorsport.net/prod...productId=1491
I wouldn't buy any after market kit until the existing suspension components have been checked and any worn bushes/joints replaced, followed by a wheel alignment. At the same time check your tyres, incorrect pressures, cheapo tyres etc, can make a huge difference to handling. Also, are you sure your rear end is working? Can you spin the front wheels?
My Bora 4mo is now running std R32 suspension (shocks and springs), R32 front lower rear control arm bushes (solid v the very flexible std 4mo ones) and a euro spec rear R32 sway bar, R32 Mags with Michelin Pilot Sport 3's.
But with all that stuff how is your understeer?
I did the ECS refresh kit about 5 years ago (minus wishbones). Standard sway Bars (F&R), Bilstein B8s with eibach springs.
Wheel alignment is good and I'm wearing Continental Contimax tyres which are unreal.
There's one set of traffic lights on my home commute, when you go through them you go hard left. Accelerating through that hard left is horrible! The understeer is just nuts. It's my test corner when I do anything to my suspension.
Mine will understeer If I chuck it into a corner and then stamp on the throttle, it's a front drive bias set up with a heavy lump up front. I find if I feed the power on through a corner it grips like a limpet. Slow in, fast out works well.
Hey gldgti why did you can your reply?
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
Ahh shame no one is doin the UM flash in aus.
