Results 11 to 20 of 25
Thread: Anti Lift Kit on Bora 4Motion
    Jul 2010
    Elanora Heights, Sydney
    Quote Originally Posted by beale187 View Post
    I was just researching Haldex Controllers... I thought HPA were the ones only offering it for MK4. Nice find Hayden, now get back to that R32 ��
    Prank, I've got the same problem.. Horrible understeer. Whiteline have discontinued the rear sways. H&R or Eibach seem to be the go.
    They are just so expensive those brands. I'm keen to try this haldex thingo but worried about side effects.
    Sent from my SM-G930F using Tapatalk
    Jul 2010
    Check this out guys:
    VWVortex.com - Your Haldex Works Powertrak Insert: Review
    Jul 2010
    That thread further feeds my scepticism. I might go rear sway first.
    Apr 2014
    Penrith, NSW
    Agreed. I did have some concern regarding the internal clutch pack, the whole thing just sounded a little too good to be true.
    I did however find the below which sounds good.
    http://www.unitedmotorsport.net/prod...productId=1491
    Nov 2015
    Hobart, Tasmania
    I wouldn't buy any after market kit until the existing suspension components have been checked and any worn bushes/joints replaced, followed by a wheel alignment. At the same time check your tyres, incorrect pressures, cheapo tyres etc, can make a huge difference to handling. Also, are you sure your rear end is working? Can you spin the front wheels?
    My Bora 4mo is now running std R32 suspension (shocks and springs), R32 front lower rear control arm bushes (solid v the very flexible std 4mo ones) and a euro spec rear R32 sway bar, R32 Mags with Michelin Pilot Sport 3's.
    Jul 2010
    Quote Originally Posted by Gez110 View Post
    But with all that stuff how is your understeer?
    I did the ECS refresh kit about 5 years ago (minus wishbones). Standard sway Bars (F&R), Bilstein B8s with eibach springs.
    Wheel alignment is good and I'm wearing Continental Contimax tyres which are unreal.
    There's one set of traffic lights on my home commute, when you go through them you go hard left. Accelerating through that hard left is horrible! The understeer is just nuts. It's my test corner when I do anything to my suspension.
    Nov 2015
    Hobart, Tasmania
    Mine will understeer If I chuck it into a corner and then stamp on the throttle, it's a front drive bias set up with a heavy lump up front. I find if I feed the power on through a corner it grips like a limpet. Slow in, fast out works well.
    Jul 2010
    Hey gldgti why did you can your reply?
    Mar 2010
    Lesmurdie
    I'm running the UM tune in the haldex, UM are a very good company to work with never had a problem with them (you have to ship your haldex controller to them). Love the tune aswell not that i've had the best chance to test it.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Sep 2008
    Berwick, VIC
    Ahh shame no one is doin the UM flash in aus.
