Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Anti Lift Kit on Bora 4Motion
    Jul 2010
    Elanora Heights, Sydney
    Hi All,
    Has anybody driven a Bora 4Mo with an ALK?
    My Bora understeers terribly, I was thinking I needed a bigger rear sway bar but now I'm wondering if I can improve it with a Anti Lift Kit.
    Anybody have experience ?
    Thanks all,
    Christian
    Gosford Central Coast NSW
    Anti lift kit is fancy marketing language for front control arm poly bushings - you know that right?
    IME, all mk3-4-5 benefit from poly bushings for the front control arms.
    However, the problem you are trying to remedy could be caused by 100 things... you might need ot be more analytic about the problem solving process.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jul 2010
    Well, its most well known for the name 'anti lift kit'.
    Considering the price, I just see it as a cheap option that may help. That said, I dont think I can DIY the install.
    Jul 2005
    All the 4mo's with vr6 understeer from the weight.A sports haldex controller removed heaps on my G4 R32. Yes sway bars do make a differenc on the VR6's aswell.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Jul 2010
    Quote Originally Posted by aprr32 View Post
    The Haldex controller is just a bit out of my price range.
    Jun 2011
    Quote Originally Posted by PranK View Post
    Darkside Developments - YHW Powertrack Insert for Haldex First Generation - 50/50
    Jul 2010
    Have you experienced this? It looks kinda promising but the description doesn't mention understeer at all.
    Sep 2008
    Berwick, VIC
    These just screw into your haldex and give you permanent AWD?
    Jun 2011
    Same effect as haldex controller. Just more permanent.
    Quote Originally Posted by BoraBora View Post
    Yep. 50/50 all the time.
    Apr 2014
    Penrith, NSW
    I was just researching Haldex Controllers... I thought HPA were the ones only offering it for MK4. Nice find Hayden, now get back to that R32 ��
    Prank, I've got the same problem.. Horrible understeer. Whiteline have discontinued the rear sways. H&R or Eibach seem to be the go.
