Results 1 to 3 of 3
Thread: All power windows not working after window reg replacement.
    Apr 2011
    Berwick, Victoria
    Unhappy All power windows not working after window reg replacement.
    Hi all,
    encountered my first problem with my golf, one of the plastic clips on the window regulator snapped this morning.
    I wasn't too fussed about that.
    I purchased a whole new inner skin excluding motor.
    The windows were working before I pulled the inner skin off the door.
    I installed it but now, all my power windows do not work at all, the connector is firmly connected on both the motor and controls.
    The door locking controls work however.
    So, I've read up a bit, and looked at Fuse "38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A)."
    That was fine but replaced it anyway, nothing.
    I have read somewhere about a mysterious S37 circuit breaker, I believe it's under the steering wheel with all the relays, can someone confirm this and guide me towards this 'S37'?
    Any help would be appreciated. Even if it's, have you checked this yet?
    Nov 2006
    Brisbane Qld
    The power window circuit breaker is that fuse sized alloy box with the green painted 30Amp label located at the very bottom of the relay plate under the dash (bottom right corner under the big double relay for the intermittent wipers).
    PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
    Aug 2007
    Its a thermo fuse, therefore comes into play when it gets too hot
    Alba European
