Results 1 to 10 of 11
Thread: Aircon pump
    May 2012
    Coffs Harbour, NSW
    Aircon pump
    Aircon has been substandard since i got the car - 99/00 mk4 gti
    so we went to recharge it but the pump doesnt seem to be running. When the aircon is
    turned on the pump engages, but pressure within the system doesnt change.
    I have checked both the high and low points.
    Before i go buy another compressor, what else could i check?
    not sure if VW have something uber special with the system?
    Jul 2007
    Brissy
    There are a few things that go wrong.
    1. The thermo fans don't jump to high speed when they need to. Sometimes a broken resistor in the fan.
    2. The control unit is stuffed. It is mounted below the battery and has 2 huge connectors on it.
    3. The field coil is gone.
    The brains is the control box. It takes signals from pressure sensor (drivers side firewall), thermo fan setting, throttle position (from Engine ECU), ambient outside temp (under bumper left side), cabin on off switch. From all this it decides when to turn on the fans and compressor.
    You say it engages. Have you watched the pulley actually spin in the middle to confirm this ?
    The engine will pick up revs when ever the compressor should be on, so that is not a good test.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Aug 2007
    Yeah mate you pretty much summed it up, if you fit gauges to your car they will just stay put with the compressor running, im sure by the sounds the compressor is defunkt. They are a variable displacement compressor and im sure itll be stuck on its stroke and itll be all scored inside, fairly common, if you look for a replacement you must get the exact one as the duty cycle is different between 4 cyls and 6cyls.
    Have someone fit a set of gauges as they never lie if they are stuck and compressor runs itll be the compressor
    Jmac
    Alba European
    Jul 2007
    Brissy
    This is probably be exactly what you need, check your part number.
    Air con compressor - mk4
    Your timing could not be better. VW charge $1200 for a new compressor or $747 just for the field coil.
    MK4 GTI - Sold
    Aug 2007
    Quote Originally Posted by JustCruisn View Post
    Yep x 2 here, just check all your numbers match, check the pressures are good but stuck with it running and then get yourself a bargain
    Jmac
    Alba European
    May 2012
    Coffs Harbour, NSW
    Thanks guys. Compressor engages and starts spinning. So I'd say the compressor. Ill check my numbers in the morn and check that one out. Might work well and good timing
    May 2012
    Cheaper option?
    May 2012
    Coffs Harbour, NSW
    Just to make sure vw haven't done something strange. If the compressor clutch engages, I can see it start spinning, can the compressor work without any change in pressure? Gauges sat on about 40psi and didn't move on both high and low side. Normally that means compressor is dead, just want to be sure
    Mar 2009
    Sydney boy
    Im going through the exact same issue. No pressue on the ac gas. Mechanic said compressor is dead. Great just what i need before xmas!
    Apr 2008
    If you get me the part number, I can see what sort of price I can arrange from ECSTuning...
    Nothing to see here...
