Results 1 to 10 of 10
Thread: airbag fault
    Redfern NSW
    airbag fault
    i've got a bag fault coming up.
    for the time being does anyone know how this can be disabled?
    can a vag-com do this? does anyone in sydney have one i can borrow?
    I keep getting an airbag code from the airbag controller. Never had any lights so I just keep clearing it.
    Airbags are over rated anyways
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Aug 2007
    Whats the fault?????? You will find making the wiring connectors tighter and then clearing the fault will do - loose connection - high resistance
    Alba European
    Redfern NSW
    i'm not sure exactly what the fault code is as I don't have a VAG-COM and I have to admit I've lost the print out I got when it was serviced.
    Their is a warning which comes up on the dash, the airbag light is on and I get a series of loud beeps on start-up.
    I wanted to see if I could come user somebody's VAG-COM, see what the problem is and see if it can be turned off or fixed.
    I have a feeling that one of the bags in the car has been deplolyed at some stage.
    Aug 2007
    Perth, Australia
    This might be a dumb question, have you tried disconnecting the battery and clearing the code like that? This usually clears the airbag codes (on non VAG cars tho)
    1991 BMW 318is RED E30
    Feb 2008
    New Zealand
    Check that the Plugs are all connected and havent vibrated loose
    in my GTI the airbag light came on cos the sub vibrated loose the seat belt roller plug
    check your seat belt roller plugs
    check your Seat airbag plugs
    and get vagcome to chekc what the actuall fault is
    if its the driver air bag its usually a faulty clock spring!
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    Redfern NSW
    Quote Originally Posted by HitmanR32 View Post
    hitman what are these plugs you speak of?
    i'm keen to get the vag-com and check the fault just need to find someone in sydney who has one who is keen for me to come over and give it a go.
    Feb 2008
    New Zealand
    ok
    this is the concept of the 50cent tuneup
    well under each seat there is a plug rig in the bottom of them..
    usually they shouldnt vibrate loose but some times they do.. there is one under each front seat
    now other airbag network plugs are dotted around here in there..
    where your front seats have their individual seat belt rollers.. there is a plug in to each seat belt roller.. so that in the even of the crash the seat belt rollers lock tight and tighten up to stop your body flying forwards
    but also behind there there should be another plug either side for the side intrusion sensors for the air bags.. all these plugs should be a yellow in colour..
    make sure they are all connected properly
    (dissconnect the battery while doing this.)
    disconnect all of them and then reconnect them just to ensure they are connected properly..
    if that doesnt seem to solve it..
    get the vag come to check the codes... and proceed from there..
    if you go to a stealership and on the off chance its a disconnected plug.. they have been known to feed you lies and charge you 600 odd dollars to repair a unit that has no need to be replaced (all they do is plug it in clear the code.. thrash your car and send you a bill..!!!!)
    - 2010 Golf R
    - 1997 Golf VR6
    Redfern NSW
    ok
    cheers mate ( bro ), i'll get onto the plugs tonight.
    i agree with you're stealership comments hence i'm trying all DIY fixes first.
    Feb 2008
    New Zealand
    it depends who you know and who you trust..
    that always has a bearing when i take the car to a dealer
    i only go where i can trust them with my car...
    generally because i know the service teams etc..
    - 2010 Golf R
    - 1997 Golf VR6
