Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 85
Thread: Air Intake setup... why cant we POD it...?
  1. #31
    Canberra
    Here's EVOMS instructions for servicing their filters, I bought a spare so I can rotate them, ie. have one cleaned and lightly oiled sitting in a ziplock bag in the garage so I just swap them over and I'm good to go, then I just service the dirty filter and it sits in the ziplock bag waiting for the next use. Never had a problem with the MAF after 12 months using the V-Flow. Notice the recommended oil drying time also:
    Evolution Motorsports
    Filter Cleaning Procedure
    Step 1: Remove filter from intake tube and venturi.
    Step 2: Using a non-detergent soap in warm water wash the filter (hand soap, Simple Green works great.)
    Step 3: Using cold water rinse filter from inside out, as to push all dirt out of the filter.
    Step4: If air compressor is available from the inside out lightly blow the water from the filter.
    Step5: Regardless of blowing all water needs to be completely removed from the filter before moving on to the next step. The filter will probably need to sit in front of a fan for 3-4 hours.
    Step6: If the filter is still red in color and completely dry then the filter can be placed on the car and the process is complete. If filter is more Grey in color see step 7.
    Step7: Our filters use a 6 gram oil spray process, so if you do decide to re oil the filter a K&N recharge kit can be used, the oil should be applied only to the outside of the filter in a very light spray.
    Step8: Let the filter dry for at least 4 hours before using preferably over night if possible
    Not sure how it can be a waste of money when EVOMS have published detailed R&D on the benefits of this setup with the 6 inch velocity stack, venturi design, etc, plus it can be serviced and used over and over ensuring the car is always running a nice clean filter.
    Snowy
  2. #32
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by Blitzen View Post
    This is hearsay and crap...There is NO proof to this....I have run K&N and BMC oiled filters on all of my cars and never had a problem, and have NEVER heard about it being an issue until I joined this forum, but of the people how come up with this stuff about buggered MAF sensors, NONE have come up with any proof to say it was the filter oil that killed it, and NONE have taken up the issue with K&N, or any other oiled filter manufacturer. Tell me, alot of the time, where dose the crank case breather hose exit in front of? Do you have conclusive proof that filter oil wrecks Mass Airflow Sensors(MAF"s).
    Please read this...
    http://www.knfilters.com/MAF/massairpledge.htm
    http://www.knfilters.com/MAF/massairfindings.htm
    http://www.knfilters.com/MAF/MAFTestresults.htm
    I knew this would get opinions racing
    I did read all the information provided in those links, very good information also.
    Blitzen, you state you have run BMC and K&N filters on all of your cars, a choice that you probably made as a well informed one and i'm guessing with a certain amount of technical knowledge about these filters. What about old mate who decides he wants a pod filter, so he rips out his stock airbox, goes down to supercrap and pays $25 for a foam mesh pod, his cousin guido says "mate, you gotta oil a pod, sick bro" and old mate drowns his el-crappo filter in oil, resulting in the oil catching all the dust and crap it should, but because old mate is an idiot, the filter doesn't hold it and it blows all over his MAF?
    I'm not trying to offend anyone or their decisions. You want to fork out big bucks for an oiled pod filter, fine. That is YOUR CHOICE. It is a well known, INTERNATIONAL problem with Volkswagen MAFs that they are ridiculously delicate, a consequence of using cheap labour in a country that cant spell "quality control".
    I personally will stick with a panel filter made of paper, but again,that is my choice.
    Blitzen, to answer your question, no. I do not have any proof. I am going off what I have been told by a Volkswagen mechanic, (sorry, they prefer specialist...). To answer your other question, I have no crank-case breather anywhere near my MAF, so i cannot comment on that either.
    Some more reading.....
    http://www.mkiv.com/techarticles/fil...t/2/index.html
    http://home.stny.rr.com/jbplock/ISO5011/SPICER.htm
  3. #33
    Jan 2008
    Quote Originally Posted by gavs View Post
    So you're not trying to offend anybody, but you're clearly stereotyping?
    Paper would be your choice, but as you stated - you have no proof to say oil filters are bad, and others have plenty of evidence to say and prove they're good - so probably isn't best to be one of the people screaming the sky is falling, because you're making others skeptics for no reason.
  4. #34
    Mar 2007
    Quote Originally Posted by D3bb4 View Post
    Snap! x 2.
    Dave
  5. #35
    Canberra
    X3
    But honestly, what has Old mate and cousin Guido, the fully sick Bros,' and an over-oiled el cheapo foam filter got to do with this? I thought we were talking about (in your words) "big bucks" filters setups that were a waste of money.
    Snowy.
  6. #36
    Point Cook, Vic
    Old mate and cousin Guido probly top up their coolant through the oil cap too. I think society goes too far when it tries to apply a moron-proof approach to everything. No wonder we are all after instant gratification.
    FOLLOW US ON FACEBOOK
  7. #37
    Nov 2007
    Coffs Harbour
    So has anyone just modded there stock airbox......we know the pods do work does a modded box work?????
  8. #38
    Jan 2008
    I cut the little fins out of mine, as was told would make a difference. Think it has a little, next step is the K&N panel filter; after that, an additional feed shall be added when i find the time.
  9. #39
    Feb 2008
    Mate, in all honesty, I had no technical knowledge about oiled panel filters before I became a Heavy Diesel Mechanic at the start of 2006. Before that, I just went off what I had read, or what my mates had said. I just went off reputation, and these companys hold that reputation among alot of people with nearly no technical experience , hence why they hold this warranty process in such high regard.
    In regards to the other question I posed, on a few engines, the crank case breather exits in front of the MAF, and I really think that oil vapour from this would harm a MAF sensor more than filter oil.
  10. #40
    Nov 2007
    Coffs Harbour
    ...this could be interesting for this topic! why i say is why spend $400 plus dollars is this mod will work.....
