Results 1 to 6 of 6
Thread: Air bag fault
    Mar 2018
    NE Victoria
    Air bag fault
    Hi there
    Need advice on a passenger side air bag fault on my 2001 2 litre Mark 4.
    Trying to get this car ready for sale and suddenly get an airbag warning light. Managed to get the car scanned and came up with an 00588:032 code, passenger air bag igniter resistance to high.
    This model has no side airbags, only driver and passenger and have pulled out both seats and floor trim to check because there is a lot of confusing info out there regarding sensors and plugs etc.
    I have today, pulled out the glove box to check the plug and it seems fine. I believe my only option now is to replace the airbag. Can this be done with a second hand unit, or does it need to match up somehow. I've had to cancel my roadworthy inspection till I can sort it out so I'm desperate for any help or advice.
    Forgot to mention the fault would not clear.
    Sent from my SM-N975F using Tapatalk
    Mornington Peninsula, VIC
    I would check if the code goes away with a resistance substitute in place of the airbag, this will prove the wiring and module are good.
    Check out this video on how to make one.
    Airbag circuit tester. DIY tool. Build your own one! - YouTube
    The VAG tools is call the VAG1630A, but you can make one cheap
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Mar 2018
    NE Victoria
    Quote Originally Posted by MIG View Post
    Yes, thanks for that idea. I can't seem to find a replacement Bag anywhere yet, hate to finally find one and find it's the same problem..
    Mar 2018
    NE Victoria
    An airbag light wont go on its own, it will need a scan tool to clear it.
    Did try that..
    Mar 2018
    NE Victoria
    Quote Originally Posted by Oldmanemu View Post
    Hi there
    Well, after going over everything I could on the CORRECT airbag, including just checking connections, inspection of the clock spring, continuity of the pins, and cleaning ground points, put everything back together and took it to a mechanic with VCDS software and the fault cleared.
    Nothing was obvious so I must of got lucky
