Hey guys,
I am about to jump into rebuilding my AGU from my 2001 Golf GTi. I've had engine rebuilt before, but never a VW engine..
My aim is to rebuild it with bits and pieces so as to up the power and maintain reliability.
In the past, I have been less than happy with the results from a "Rebuild". Maybe I took my past engines to less than average workshops. This time when I have it rebuilt, I'm going to source all the parts first, then just drop them into the engine builder, so as just to pay for labour.
In saying that, I only have minimal mechanical knowledge, so I need to ask for some assistance please....
If I want to totally refresh the motor, what do I need to buy for the bottom end AS WELL as the top end??
I've seen new rods
IE 1.8T 144X19 Drop-In-Rods VW Audi
(I've heard they are necessary when you want to up the power)
And the rod install kit from Integrated Engineering (which I think is American)
IE 1.8T 144X19 Drop-In-Rods VW AudiIs that EVERYTHING I need for the bottom end?? or is there other stuff that I need to get in conjunction with this?
Do I NEED to get new forged pistons?? I've read conflicting reports that the AGU does have Mahle Forgies standard... Is it necessary to get new pistons?? Or if they look ok, can I just reuse the standard ones??
I'm not looking to bore or stroke the motor.
AS for the head... well I'm at a loss.. I understand the AGU is the big port, so it doesn't really need to be ported, and could in fact be detrimental to spool up time if I did?? Can I leave the head stock? Does the cam need to be upgraded if I'm going to be using a bigger turbocharger?
And last but certainly not least, The turbo itself... I see a FrankenTurbo that looks good value the F21 -
https://www.ecstuning.com/Volkswagen...ger/ES2840949/ Has anyone used this before? It just looks like a beefed up KO3... The good thing is it looks like it will fit up to the stock location etc.. And you can run a stock tune (Until I get more money for Injectors/Standalone)
Would I be better off spending a bit more money and trying to get a GT28xx in there instead?? (I know the answer will be yes if I can afford it... but I don't wanna spend a gazzilion dollars)
Cheers guys, I look forward to your advice!
Kris
