Results 1 to 10 of 13
Thread: Aftermarket Radio Antenna Plug for MK4 Golf's
    Aug 2009
    VIC
    Hey Guys
    Not sure how many of you have encountered this before and had a search around which didn't bring up much. Just wanting to know if any of you have obtained an aftermarket adaptor which allows you to connect any aftermarket headunit to the factory antenna cable.
    If so where did you source it from as a couple of audio stores i've approached wanted $40 for the pleasure which i thought was a little excessive. Theres a few i saw up on ebay for a quarter of the price but not really sure if its what i should be getting.
    Hopefully what i described makes sense...
    Cheers guys
    Naz
    I got mine from JB... But got it thrown in for next to nothing from memory...
    Sorry not much help but $40 does seem steep... Ill try find the brand for you
    yher i had the same problem, lucky as i had one handy...
    i paid around $10 for mine from autobarn or one of those places
    1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
    ''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
    LOL!!
    jaycar has them for $5max
    Aug 2009
    VIC
    Jeez thanks a heap to all that contributed to the topic... i knew it was quite extortionate lol
    Thanks AGO41T for pointing out JayCar had them. Quick visit to the website and bang there it is
    http://www.jaycar.com.au/productView...T&SUBCATID=526
    Will go check it out during my lunch break at work tomorrow !
    Thanks a heap guys .. will be finally able to listen to the Hamish and Andy show on the fox lol !!
    May 2009
    You can buy just the European aerial plug for $4 from Autobarn or probably any of the other stores. But the issue with using just the adaptors is that the reception comes out shocking. The one that you were quoted $40 on would have been the plug with the booster in it, which is what the mk 4's need so that the radio will sound good.
    Dec 2009
    Mt. Colah, NSW
    Resurrecting old thread, since I replaced my stock Eurovox with a Sony head unit today. The adaptor from Jaycar will indeed give lousy reception, because it's missing a bit. There should be a small pin in the centre of the part that connects to your antenna cable.
    HOWEVER!! If you still have the Eurovox HU, you can just pull this pin out of it (comes right out with a pair of pliers) and push it in place. Works a treat, good strong signal strength.
    Jun 2009
    Quote Originally Posted by NJAY87 View Post
    what head unit did you end up getting?
    i am so sick of fiddling with my fm tuners.
    Aug 2007
    Perth, Australia
    I paid $40 for mine from alberts. It is steep, but its a quality product. And for $20 more than autobarn/jaycar i think its worth it. The reception is crystal clear eventhough i just cut off the top of my antenna
    1991 BMW 318is RED E30
    Aug 2009
    VIC
    Merlin 8r- Hey mate you were right about the Jaycar adaptor giving lousy reception. Well lousy is a little over the top, but in some areas i get crappy FM reception, but regardless of where i am i dont get any AM reception.
    What is this small bit you refer to that is missing? Do you have a picture you should show me as to? Are you referring to the pin like dead set in the middle of the plug? I think i know what your referring to but dont want to pulling out the wrong thing
    Justin - I just ended up getting my self an Eclipse AVN unit. One of those all in one units. Only pain was getting it to installed securely into the plastic cage as it doesnt come with any mounting hardware or that metal cage alot of head units come with. Also i have a gap around the edges which i might see if i can get soem plastic fascia trim to fill it with
    Nik - Is the one you both for $40 just the adapter plug? Or does it have like an amplication module with it as well?
