Page 7 of 7 FirstFirst ... 567
Results 61 to 65 of 65
Thread: Aero-Wipers working like new again for $4.00
  1. #61
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by themarvel2004 View Post
    Yeah, seems I chose poorly - go the Trico ones. I gather they have some others which are better suited so I'm heading back tonight.
    Hopefully I can find ones that work.
    The cheapy Mechpro plastic backed refills that Repco sell also have the wide base but I was told the rubber is harder than that used in the Repco branded blades which would make the Mechpros more likely to smear.
    The ones I listed above work great on both our Mk6 Golf (which has the same wipers as your Mk5) and my Polo (which has the same wipers as the Mk4 Golf from what I can tell)
    Resident grumpy old fart
  2. #62
    Oct 2014
    Well, the conclusion is - no joy. Found some inserts that were just the rubbers - but even they could not be slid into the standard arm.
    In the end, I went to VW this morning and got the proper one. Apparently on "special" at $65 for the set... ouchy.
    Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
    Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
  3. #63
    Oct 2010
    Melbourne, VIC
    I don't understand. What stopped them going in?
  4. #64
    Jul 2012
    Bendigo, Victoria
    Had same trouble inserting 6mm refills from Bursons into mk 5. Could get almost on but then friction took over. Ended up dismantling and piecing back together. That was 12 months ago, so can't remember exactly how. Just remember it being a bit fiddly but easier than trying to pull the refill through.
    Sent from my Nexus 7 using Tapatalk
    MY 09 JETTA 118 TSI 7 spd DSG
  5. #65
    Oct 2010
    Melbourne, VIC
    I found that once the wiper refill was most of the way in, it would get very tight but the solution was to pull in more rubber down to the middle of the blade so it was a compressed in there which made it far easier to pull through to the end.
