Originally Posted by
themarvel2004
Yeah, seems I chose poorly - go the Trico ones. I gather they have some others which are better suited so I'm heading back tonight.
Hopefully I can find ones that work.
The cheapy Mechpro plastic backed refills that Repco sell also have the wide base but I was told the rubber is harder than that used in the Repco branded blades which would make the Mechpros more likely to smear.
The ones I listed above work great on both our Mk6 Golf (which has the same wipers as your Mk5) and my Polo (which has the same wipers as the Mk4 Golf from what I can tell)
Resident grumpy old fart
