Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 65
Thread: Aero-Wipers working like new again for $4.00
  1. #51
    Jun 2009
    Melbourne, VIC
    That's some good bumpage right thurr. Thanks!
    VW Bora V6 4motion
  2. #52
    Jul 2007
    Brissy
    Did this today on the MK5. Kmart want $8 for the refills now
    MK5 needs 24inch / 610mm.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
  3. #53
    Jan 2014
    Narangba QLD
    oooo. will have to give this a go.
    certianly a lot cheaper than the alternative.
  4. #54
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by JustCruisn View Post
    The Aunger ones? I couldn't find Tricos at my local KMart.
    I used the Repco ($19 less 20% this month) plastic backed blades for our Mk6 and 9N3 Polo as these have a full width, flat retaining section (the bit that holds the blade in) like the original blades (just had to remove the plastic backing). Most of the refills have a narrow retaining section and I was worried these could pull through the groove
    Resident grumpy old fart
  5. #55
    Jul 2007
    Brissy
    Yep They had a generic blue one and the Aunger ones with graphite.
    Hmm graphite gets on your fingers dunno how it helps clean the windscreen though.
    MK4 GTI - Sold
  6. #56
    Oct 2010
    Melbourne, VIC
    I think the graphite helps by stabilising the rubber vs UV and also lubricates the blade against the glass to prevent squeal.
    I'll try a set of the Aungers on the in-laws Camry
  7. #57
    Jul 2007
    Brissy
    Quote Originally Posted by kaanage View Post
    Graphite don't help the wipers when its all over my fingers
    I assume there is enough stuck on there to not just wash off on the next rain.
    MK4 GTI - Sold
  8. #58
    Oct 2014
    So the refills I got from Repco had a plastic backing which doesn't fit. But if I remove the plastic backing the groove in the rubber would be too shallow and just pull out. Where do I get the right refill blades which are just the rubber section and nothing more?
    Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
    Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
  9. #59
    Oct 2010
    Melbourne, VIC
    Which refills did you buy?
    I specifically bought the Repco branded 6.5mm plastic backed refills since they have the full width holding section. There's no way these would pull out without tearing the rubber
  10. #60
    Oct 2014
    Yeah, seems I chose poorly - go the Trico ones. I gather they have some others which are better suited so I'm heading back tonight.
    Hopefully I can find ones that work.
