Results 1 to 4 of 4
Thread: Advise on wheels would appreciated
    Jul 2011
    Was thinking of fitting a set of genuine 18" velos rims part number 3c0071498a 235-40-18 18x8 my stud pattern is 5/100 will need to space using 5/112 adapters any advise on what size spacers would make them look the best front and rear. And any other opinions would be helpful regarding fitting issues or choices, thanks
    assuming the ones you are looking at are 18"x8" ET44?
    well you wont be running any crazy fitment with a 235 on a 8.
    id say 15mm adapters (minimum size available without spending silly $$) up front and 20mm on the back, giving you a 8et29f and 8et24r.
    maybe look into some 215/40s or 225/40s? and are you lowered? if so how much
    Jul 2011
    Not lowered at the moment still deciding how low to go?? If I decide to fit these wheels..
    Jan 2008
    Canning Vale, Perth, WA
    just be aware that spacers/adapters are probably not actually legal and so you might run the risk of voiding your insurance.
    Think about that when deciding
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
