Hey guys, i have a mk4 gti AGU engine...
I've been massively down on boost since having it tuned and its taken some time to try and rectify it.
I had an N75J (ecs race n75) installed, and tried going back to my stock one and neither made much difference, just the n75j got about 2 psi more... so i was hitting either 7 psi or 9 psi with either one, instead of peaking at 21psi and holding 19psi as the race tune was supposed to..
Considering i had not much luck with either n75 i figured my problem lay elsewhere. I've been mucking around in my spare time and i tried disconnecting the N75 top hose that heads to the wastegate and plugging it.
Whilst i get some boost cut and jerking (avoiding WOT, and in 3-4th), im climbing up towards 20psi no problems.
I'm just trying to work out whether this test points to
a) a weak wastegate
b) a dodgy boost line to wastegate
c) a dodgy n75
d) any of the above (or specify other).
I originally thought the n75 was fine as id tried my oem and the ecs a/m variety. Whilst looking around i found some turn of the century audi's go into soft limp with the ecs n75j, so figured it may be the same issue with mine? And as such need a new oem n75?
any help will earn cookiescheers
