The only advice I could give is be careful your front sway bar doesn't hit your drive shafts if you go too low....as I believe it does in MKIVs
hey guys,
im highly considering lowing my car purely for looks. Ive got a 1999 golf gti. i was wondering if i could gather some recommendations on suspension shops that might be able to point me in the right direction. i really just wanna talk to some one about it and figure out a good option and grab a couple of quotes while im at it. im based in melbourne around the east suburbs. ive done a search on the forums for a thread that might cover this but couldn't come up with much.
hopefully some one can help me out seeing as i dont really have much of a clue haha
thanks guys![]()
2010 90TSI Manual / Comfort Pack / United Grey
RICE - Leave the useless wings to the Penguins...
^^ thanks for the advice. i was also thinking about maybe putting it on bags.. again my knowledge is minimal to all this..
so no one could recommend a suspension shop or some one i could talk to who could helP?
this^^ approx 40mm drop will require a replacement sway bar or end links depending on how low you plan on going.
if your looking to go any more then 40mm with just springs id say get new shocks too.
if you getting new shocks it becomes a bit more pricey and id be looking at coilovers.
if your wanting to really lower the car get air ride as aussie roads suck for lowered VWs
yeah, im leaning more towards the hole coilover thing, unless getting an air ride + install and all that isn't outrageous.
Brand new air ride suspension is expensive. Maybe you could look at eibach prokit or streamline with some Koni str .t shocks about 700 shipped
depends what level on air ride you want to how much it costs, can get kits designed for mkiv cheap like $2k+ from ECS or put it together yourself.
Coilovers will get you fairly low enough, its just a matter of if you can drive it :p
Air ride, i only know of 1 crowd in melbourne: Air Ride Suspension Supplies - Air Ride Suspension Supplies - Air Suspensions Systems and Auto Electrical Products for Rods, Customs and Classics
I had mine done by a chap in Queanbeyan, NSW (town attached to Canberra, ACT).
>> Inline Steering & Suspension, 32 Yass Road (02) 6232 9955 <<
Really good guys, very knowledgable about several european rides, including VWs.
I was referred to them by other VW drivers in Canberra, and I found them really approachable about discussion ride heights for Bora's etc.
Might not help you being in VIC, but anyone else might find them useful.
Tedd
audi-tone has mentioned that you can get KW v1 coilovers for 850 landed from dpm.
So the question is to you want to be able to adjust the stiffness?
ECS also have some cheap coilys.
Can also verify that the distributor for KW in Australia is in Melbourne!
Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
Get a new front sway bar and some fk coilovers - they apparently go very low. Lower than kw's; I'm sure the ride isn't as good but if it's just for looks I assume you don't care about the quality of ride??
But if you have loads of money then grab some bagyards.
Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
