For what its worth I found my ABS problem was due to the left sensor bolt coming loose, the sensor was moving around. I tightened the bolt and all is good.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
VAG pointed to the module so its either fix or replace i spose
01 Golf GTI
95 Golf Cab
67 Type3 Fastback (Kermit)
62 Type3 Square
i got the same problem, ever since i moved my battery slightly to the left to make room for the pod my ABS light keeps flicking on and off while i drive...
Like they said previously the ABS fuse is on top of the battery, so make sure you didnt stretch the wiring or something. The ABS wires come out through the separate plug on the back of the fusebox on top of the battery.
There are also two small earth points under the battery tray which are for the ABS system earths. There are two really big earthpoints and then the ABS ones are the smaller ones towards the back of the car but still on top of the chassis rail
...or you now have so much power with your pod filter the ESP is kicking in![]()
PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
fixed the problem i did stretch the wires thanks.
