Results 1 to 10 of 14
Thread: 4spd to 5 spd, is it possible??
    Apr 2019
    Lightbulb 4spd to 5 spd, is it possible??
    Hi Guys,
    Just wondering. In light of the 4 spd auto trans failing in my 2001 Golf, I was wondering if that can be replaced with a 5 spd auto? What issues may I come across or is it just a case of taking out the 4 spd auto and bolting on a 5 spd auto and drive away?
    Any thoughts???
    Regards
    Steve
    What car do you plan to get the 5spd auto from?
    If not a mk4 the list could be endless
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2014
    Penrith, NSW
    Pretty sure MK4 Golf Auto's are all 4sp. HOWEVER to keep in the same generation a 5sp from a V5 Bora should bolt up easy enough. Only thing I could think of you may need to do is program the ECU with the appropriate gearbox code.
    Quote Originally Posted by beale187 View Post
    Did they do a 5spd auto on the v5...? Thought they were all 4.
    Bell housing on the 5cyl is based on the 6cyl cars so won't directly bolt on to a 4cyl petrol, would need to change or adapter that too
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2014
    Penrith, NSW
    From 2002 - 2005 the V5's were a 5sp Sports Auto.
    Dylan is spot on about the bell housing too... Knew I shouldn't have commented on things that aren't VR's...
    There ya go! Wonder what was in stus wagon, I'll have to go back and check.
    Ha I only know because gearboxes are an on going hunt for both my cars. Vento has gone from 4spd auto, 5spd, short ratio 5spd, now I want a 6spd with short ratio and long 6th
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2014
    Penrith, NSW
    Something thirsty would be my guess...
    To avoid the use of an adapter would a 5sp Sports Auto from a 1.8T Passat be a better option?
    Passats are mounted the other way so not sure if the gearboxes are even close to a mk4 style
    Sent from my HTC 2PZC100 using Tapatalk
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2019
    Thanks guys,
    4spd autos are becoming a unicorn
    Apr 2014
    Penrith, NSW
    Have you tried
    Stock list - U Pull It
    They have 1/2 doz odd MK4's, and they're in S.A.
