Results 1 to 10 of 14
Thread: 4spd to 5 spd, is it possible??
    Apr 2019
    Lightbulb 4spd to 5 spd, is it possible??
    Hi Guys,
    Just wondering. In light of the 4 spd auto trans failing in my 2001 Golf, I was wondering if that can be replaced with a 5 spd auto? What issues may I come across or is it just a case of taking out the 4 spd auto and bolting on a 5 spd auto and drive away?
    Any thoughts???
    Regards
    Steve
    What car do you plan to get the 5spd auto from?
    If not a mk4 the list could be endless
    Apr 2014
    Penrith, NSW
    Pretty sure MK4 Golf Auto's are all 4sp. HOWEVER to keep in the same generation a 5sp from a V5 Bora should bolt up easy enough. Only thing I could think of you may need to do is program the ECU with the appropriate gearbox code.
    Quote Originally Posted by beale187 View Post
    Did they do a 5spd auto on the v5...? Thought they were all 4.
    Bell housing on the 5cyl is based on the 6cyl cars so won't directly bolt on to a 4cyl petrol, would need to change or adapter that too
    Apr 2014
    Penrith, NSW
    From 2002 - 2005 the V5's were a 5sp Sports Auto.
    Dylan is spot on about the bell housing too... Knew I shouldn't have commented on things that aren't VR's...
    There ya go! Wonder what was in stus wagon, I'll have to go back and check.
    Ha I only know because gearboxes are an on going hunt for both my cars. Vento has gone from 4spd auto, 5spd, short ratio 5spd, now I want a 6spd with short ratio and long 6th
    Apr 2014
    Penrith, NSW
    Something thirsty would be my guess...
    To avoid the use of an adapter would a 5sp Sports Auto from a 1.8T Passat be a better option?
    Passats are mounted the other way so not sure if the gearboxes are even close to a mk4 style
    Sent from my HTC 2PZC100 using Tapatalk
    Apr 2019
    Thanks guys,
    4spd autos are becoming a unicorn
    Apr 2014
    Penrith, NSW
    Have you tried
    Stock list - U Pull It
    They have 1/2 doz odd MK4's, and they're in S.A.
