2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff| Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
I agree. So, I am looking for an OEM clutch and flywheel kit to replace the heavily glazed and worn one that I have removed.
To finally remove the gearbox, I dropped the subframe [4 bolts], then unbolted the steering rack.
Since I will be removing the flywheel, I will replace the main oil seal as well.
Can anyone suggest parts sources?
Thanks...
How did you go?
How many k's has your car done?
Paul
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Tony did you get bolt out of shaft or did you drill it out ? My bolt is in so tightly I can feel the 6mm hex starting to turn inside the bolt and strip. Someone must of been in here before. As it’s very tight. I don’t want to snap it
